Hello, our company designed a board that hosts a Raspberry CM4 and we implemented a solar charger using BQ24650RVAT.
The design itself is nearly identical to the one proposed in the datasheet but for some unknown reason the board is not working.
Our engineer made some checks and discovered that the pins SRN, SRP and VFB are all connected to ground causing a shortcircuit when given power.
In fact we tested it and the SRP track blow up. I hope someone can provide some more insight on this problem.
Our current design for the charger:
