Other Parts Discussed in Thread: TPS25751
Is it possible to replace the TPS25751 with TPS25730? if yes, is it direct drop-in replacement?
Thanks for reaching out on E2E!
It is possible to swap those parts but there but there are some changes needed to make the TPS25730 work properly.
They share the same package, size, and almost identical pin out.
Please refer to the datasheet as you will need to configure the ADCIN pins on TPS25730 to get it to work properly.
Thank you,
Kevin Kosta
