Dear Team,
We have designed a 18V @5A output from a 12V input using TPS61288.
While checking we found out that at around 3.5A the IC is getting heated up and output drops to 11V.
I hope this is happening because of thermal shutdown, but when we use a fan the IC is working fine upto 4.5A.
Our PCB is 2 layers and for circuit we followed webench.
Is there any other way to reduce heat in the IC or if there is anything we missed in our design, which leads to more heat dissipation?
Dharun S
