[FAQ] TPS65987D: Can I tie ADCINx to LDO3V3 directly using a pull-up resistor for DIV max = 1.00 settings?
Part Number: TPS65987D
When biasing the ADCINx boot pins, if I select one of the settings where the DIV_MAX is 1.00, can I directly tie the pin to the LDO3V3 through a rail?
