LM5177: Sync pin high or low?
Part Number: LM5177
I am not using current monitoring the LM5177 design I am working on and I have ISNSP and ISNSN tied to gnd.
Do I put the sync pin to AGND or VCC?  On page 5 of the datasheet under the sync pin info it says: "If this function is not used, connect the pin to VCC".  However on page 28 of the datasheet it says: "If the synchronization function is not used it can be pulled low continuously".  In the web bench design it tied the pin to ground.
Thanks!
