Other Parts Discussed in Thread: LM317, TPS7A16A-Q1
Due to some circumstances. We are having to operate at Vin - Vo = 45V. The losses in the LDO would be 2.1W. The thermal design is very good and temperature of the device is not crossing 80C on the case. What kind of failure mode can we expect? We want to make 100 boards with this configuration.
Can you recommend a pin to pin drop in replacement with higher Vin-Vo rating?
Vin = 60V
Vout = 15V
