For our application, I think we can use this regulator. Our goal is to generate +/-5V.
I am thinking I can connect PGND = AGND = -12V, Vin = +12V
Would this work? My assumption :Rail levels are maintained and I should Vout-AGND levels = same as what it would be with PGND=AGND = 0V and Vin = 24V. Is this assumption correct?
Also, I notice in the user application that the there are two grounds shown in the block diagram. Can you please explain an example use case for the same?
