Part Number: TPSM843A22
Other Parts Discussed in Thread: TPS543B22EVM, , TPS543B22
I will sync the TPSM843A22RDGR with an external clock. The datasheet suggests using a buffer for the clock to properly read the fsel resistor. Is there any known good MPNs for this buffer? I can not find a suggestion in the datasheet or the eval board schematic. It probably need to have a tri-state option (OE) to ensure proper startup? as this PSU will power an FPGA which again controls the sync signal.
