LM5155: Self-Sync Behavior
Part Number: LM5155
Hello all,
Thank you sincerely for the guidance you provide here. I am designing a device with a few LM5155's using frequency synchronization. The design is working great with an external clock pulse provided to the SYNC pins described in the datasheet. I am currently using the sync without UVLO, so the only component on the sync bus is the clock generator. As I said, the design works great.
I removed the clock generator while working on one of the prototypes, and noticed that the LM5155s continued switching. What's more, they continued to switch IN SYNC.
Here's my question: am I missing something in the datasheet, or is self-syncing expected behavior? I thought an external clock pulse was required in cases of synchronization, but I'd be happy to skip the external clock gen on smaller designs.
Just let me know. Thanks
