We need to choose the DC/DC buck, and the spec.: Input voltage 28V, and output voltage is +15V and -15V, output current is 1A, can you help to promote the suitable DC/DC for this request? thanks.
Can you please clarify the following:
You need two bucks that convert 28V to +15V and another that generates -15V ?
Hi Pramanik,
We consider to use one DC/DC that input 28V and output +/-15V, if there are no promotion, please promote two bucks that output +15V and -15V, thanks.
Please find the attached application note containing the generation of positive and negative power supply rail.
Create a Split-Rail Power Supply with a Wide Input Voltage Buck Regulator (Rev. A)
This device can support maximum current of 1.5A. This suits your application.
