Is it possible to configure the BQ25751 such that we can omit batfet and only provide a regulated output in 'reverse mode'? Would it be enough to set EN_AUTO_REV and configure ACOV/UV?
Hello Thomas,
Yes, This should work. If you remove BATFET, I recommend connecting Pin 32 (SYS) to Pin 33(VAC), leave Pin 15 (BATDRV) floating, and connect Pin 16 (BATSRC) to SRP.
Christian.
