Other Parts Discussed in Thread: TPS1HC30-Q1, TPS2H160-Q1, TPS4HC120-Q1
Hello all,
I tried to switch on an capacitive Load which is about 100µF. But in that moment I switch that on overcurrent is detected and the switch will turn off immediately. I checked the power supply, this is not the issue.
Am I right, that I cannot switch a capacitive load with this switch? What do I need to do to switch such kind of a load with TPS2HB50-Q1?
I want to avoid additional losses by adding a resistor in series to limit current.
Thanks in advance!
Best regards, Alex
