Hi everyone,
I am trying to load a patch file to TPS25751D. My use case is power sink(consumer) only. I attached the config file.
The problem is I am sending the patch data with 32 byte transmissions.I am using a teensy 4.1. In the end I get no I2C errors but device is stuck in PTCH mode. Can you help me solve the issue?
I have attached the I2C log file, patch data, and the code.
USBPD_flash.cppcapture.txttps25751.h
Kind regards.
-Sukru
