Hello, expert.
The SPI waveform of TPS92682 is also measured. The waveform of TPS92520 is found to be different. The rising and falling time is relatively long. Our configuration is as follows: 1 TPS92682 +3 tps92520, the MISO pull-up resistor of TPS92682 is 2k, and the TPS92520 pull-up resistor of each piece is 4.7k. We try to remove the pull-up but the effect is worse.
We want to know the reason why the rising edge and falling edge slow down, is it related to PCB?
