Other Parts Discussed in Thread: BQ25505, TPS2121
Hello TI Team,
I am looking for a single-chip power management solution that can handle multiple input power sources, charge a Li-Ion backup battery, and provide multiple output voltages while supporting communication via I2C/SPI for monitoring and control. Below are the detailed requirements:
Input Power Sources:
External Input Source: 5V to 20V
USB Input Source: 5V
Solar Panel Output: 2V, 0.3W (Adafruit Product Link)
The solar panel will be always connected, but at night it becomes unusable.
In such cases, either the USB input, external input, or battery backup will be used.
Battery Backup:
3.7V Li-Ion Cell, 7800mAh
The battery must be charged from any available input source (External/USB/Solar).
Built-in fuel gauging is required to monitor battery status.
Output Power Requirements:
12V @ 350mA
5V @ 2A
3.3V @ 2A
Control & Monitoring:
The power system should be monitorable and configurable via I2C or SPI communication.
Required Features:
Priority-based power selection (Auto-switching between inputs)
Efficient MPPT charging support for the solar panel (i.e: SPV1050TTR)
Battery charging management with safety features
Fuel gauging for battery monitoring
I2C/SPI communication for control & status monitoring
Can you please suggest a single-die PMIC (Power Management IC) from TI that can fulfill these requirements?
Thanks in advance!
