TPS92641: about the frequency
Part Number: TPS92641
Hi teams,
TPS92641 wants to achieve strobe function with a frequency of 10K, but using UDIM pin PWM control can only achieve 3K.
How to achieve higher frequencies? Is it through SDIM pins?
  • Hi Chu
    Can you please share where did you see the spec for UDIM f_res<3k?
    Yes the external shunt FET pwm dimming is recommended for higher frequency and time resolution PWM dimming.
    Can you please kindly share what's the customer and the EE&application needs?
    Thanks and best regards.
