TPS65381A-Q1: Regarding State Transition
Part Number: TPS65381A-Q1
Hello team,
My customer would like to use this device, but has several questions.
Would it be possible to answer them below?
Question1
When WD_FAIL_CNT becomes more than 5, ENDRV will be LOW, but TPS65381A will not go SAFE state. Correct?
After that, if WD_FAIL_CNT becomes 4 or less, the ENDRV will be HIGH again. Correct?
Question2
Will number of DEV_ERR_CNT be increased without limit, unless MCU writes via SPI?
Question3
We understand that if WD_FAIL_CNT >7+1, then device will go RESET and reboot.
Is there any register which can memorize that the device was rebooted by WD_FAIL_CNT >7+1 previously?
Kei Kuwahara
