Hi Team
The following LM5116 circuit,Vin=50V,Vo=3.3V,L=4.7uH,Cout=150uH,VCCX=12V,Enable the device after Vin is ready,but customer found LM5116 will output high side and low side driver signal simultaneously to cause shoot-through,and LM5116 will be damaged as well.
CH2 low side driver signal,CH4 high side driver signal,CH1 EN pin,CH3 COMP pin
Can you help to confirm if you see the same behavior for our device? why does it happen and how to address this?
