BQ25756: BQ25756 change to system load node
Part Number: BQ25756
Hello TI team,
Is it acceptable to change the system load node as follows?
Because, I want to know battery current exactly without system load current, also control to charge current, only considering battery.
If I supply input power enough, does it possible?
Thank you.
  • Hello Ben,
    No, This is not recommend. The BQ25756 uses the current sensed acrossthe RBAT_SNS to measure the inductor current to calculate the DCR of the inductor. If you apply a load on the other side of the sense resistor, the RBAT_SNS will not be able to measure the correct inductor current and the system could be come unstable.
    Christian.
