I require assistance in setting up a test set-up for the EVM. I am using Rigol Electronic load to check for the current output.
When I connect Vout and Gnd of the EVM to the Rigol load and set it in Continuous current mode at 10mA. Before turning the load on I am getting the desired output voltage but when I turn on the load the voltage drops to 0.
What might be the issue behind this?
I am using the device in Any out mode where I have shorted J8 connector and set the configuration to get 3.3V output. Please let me know the right set-up so that I would be able to get the output of at least 700mA.
Thanks & Regards
Sudhir D
