Does the Bq24650 have Power Path functionality integrated or do I need to add an external circuit. And if I do need to add one, is there an app note on it?
-Jordan
bq24600/20/40EVM uses /PG pin signal to drive external power path circuit. Please copy that circuit to do the power path function.
bq24650 has similar pinout, you can put bq24650 IC to a bq24600/20/40EVM to verify the power path function.
bq23650EVM
bq23650EVM use
bq23650EVM uses
bq23650EVM uses two
bq23650EVM uses two diode
bq23650EVM uses two diode to
bq23650EVM uses two diode to do
bq23650EVM uses two diode to do the
bq24650EVM uses two diode to do the power path
