Hi Team,
I want to use the following wake-up configuration when charger is connected, which is mentioned in Parallel Paths document
I need a verification if this circuit helps me to pull down the TS2 pin below 0.7V(0.7V is the max voltage at TS2 pin to stay low)
Pls help me with this.
Thanks and regards,
Karthik.
