TPSM33625: Thermal Measurement
Part Number: TPSM33625
There're few questions about thermal measurements on control board in MD.
Since recommended TJ, max is specified as 125degree, customer would like to estimate TJ more precisely.
1. What's the difference between the thermal parameter 1 RθJC(top) and 2 (ΨJT) as red marked below diagram?
What parameter do you recommended to use? Why?
2. Since in the some cases, the thermal wiring is not easy to attach close to device as PCB size is slim and components is dense. Do you suggest to use parameter of RθJA (Junction to Ambient) for thermal estimation in practical? If so, where location putting the thermal wire measured point is more accurate for ambient temperature? Is there use guide for setup?
Using New Thermal Metrics.pdf
Brian
