TPS62442-Q1: Regarding Rcf at COMP/FSET
Part Number: TPS62442-Q1
Hi Expert,
    I am also facing similar issue as this thread : -Q1: Regarding Rcf at COMP/FSET - Power management forum - Power management - TI E2E support forums for calculating Rcf in comp setting 1 with SSC enabled. I would like to operate DC regulator near to maximum supported switching frequency considering 20% tolerance of SSC. In this case it is coming to be less than 3.3MHz. What value of Rcf would you recommend to achieve safest maximum supported frequency with SSC enable in comp setting 1?
Sivaprasad
