TPS61200: Too much shutdown current using the UVLO-function
Part Number: TPS61200
Hi all,
In one of my projects, I used the TPS61200. The main reason for choosing this IC was UVLO function.
This UVLO behavior has also been confirmed in the following topic:
e2e.ti.com/.../tps61200-vout-behavior-when-uvlo-is-triggered
However, during testing, I noticed that when the input voltage drops to around 0.7 V, the output is turned off, but the shutdown current is still around 2 mA.
I found a topic related to the TPS61200 where the same issue is described:
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/733216/tps61200-tps61200-draws-too-much-current-using-the-uvlo-function?tisearch=e2e-sitesearch&keymatch=TPS61200#
could you help me how to get very low shoutdown current when UVLO is active?
Thanks in advance!
