Other Parts Discussed in Thread: LM317
Hello
I made a design using TPS560430YF, please check the images here: https://imgur.com/a/tV1q3US
I optimized the layout as much as possible in the current board, no other space is available. input caps are not perfect but very good. 2x100nF 0402 caps are very close to Vin pin as well as other 1x10u 0805 + 2x22u 1206 caps.
the selected feedback resistors as follows:
12v
R_top = 243k
R_bot = 22k
9v
R_add = 649k -> this is switched using the switch to either be out of the circuit or in parallel with top resistor 243k to form about 176.5k top resistor for 9v.
please check the calculations as well as layout and provide your feedback
thanks for your kind support.
