I have connected a 10k Ohm NTC to the TS pin and am trying to read the data from the Pin, however the temperature reading I am getting is incorrect. I have NOT connected any Pull Up resistors since in the TRM, it said that there is an internal pull up.
I am also unsure how I need to process the data I get from the TS pin. Should I be using a look up table to convert the data into degrees Celcius, or is there another way?
I am using an STM32 as the main MCU in my system. Any help here would be much much appreciated. I have been stuck on this for a couple of days now.
Thanks you very much,
Anand
