When implementing Lowside Protection, is it correct to understand that it is okay to connect VSS as shown in the second image rather than the red frame in the first image?
Nishie
Nishie
Hello Nishie,
The conductivity of both images are the same. VSS is connected to ground or the negative terminal of the battery and the thermistor is connected through TS >> Thermistor >> GND.
Thank you,
Alan
