Dear TI experts,
My customer drew 1st schematic using LMR38025-Q1. Could you review the schematic below?
Chase
Dear TI experts,
Chase
Hi Chase,
What is the load current in your application?
Is the input voltage fixed at 48V or is there a range of operating conditions?
Niranjan
Hi Chase,
The input filter will need damping or it will be unstable. I would recommend adding a high ESR electrolytic cap in parallel with the input caps (to the right of the inductor).
Also, the minimum recommended input cap is 4.7 uF ceramic. I would suggest changing either one or both of the 2.2 uF caps to 4.7 uF.
Niranjan
