BQ40Z50: Questions regarding FCC and SOH decline after cycle test
Part Number: BQ40Z50
Hello.
TI Technical Support Team
After the charge/discharge cycle test of the PCM that applied the learned golden file of the BQ40z50 Chip, the problem of FCC and SOH decreasing intermittently occurs.
This may be a problem with the Main IC of the charger/discharger for the cycle or a problem with the cable.
However, I am having difficulty verifying this.
Therefore, I would like to inquire about how to prevent the FCC and SOH of the PCM that applied the learned golden file from being updated and about the problems that may occur if the FCC and SOH are not updated.
I will wait for your reply.
Thank you.
