BQ25792: BQ25792: BATP Pin Input Resistance
Part Number: BQ25792
Hi Ti E2E,
The datasheet for the BQ25792 chip mentions
"Positive Input for Battery Voltage Sensing – Connect to the positive terminal of battery pack. Place 100Ω series resistance between this pin and the battery positive terminal."
What would happen if I used a 10Kohm resistor on that line instead of a 100ohm resistor? Would the BQ charger not be able to monitor the battery pack voltage as closely and cause charging issues?
