Other Parts Discussed in Thread: TPS51396, TPS568230
Dear support-team,
I have a short request regarding a Step-Down Voltage Regulator (TPS51396A) from TI.
In the Application Report "SLVAF11" it is described how to select an LC-combination for a stable regulator. However, to follow this calculations two regulator-specific constants "Acp" and "ωRI" are needed.
For me the following questions arise:
- Is this Application Report even applicable to this regulator?
- Are the parameters "Acp" and "ωRI" available on your side? Would it be possible to send these parameters to me?
- In the datasheet of the regulator, there are specified some recommended component values. For the minimum Output-Capacitance, is it possible to use a lower value than specified if the system would still be stable according to the Application Report "SLVAF11"?
Thank you in advance!
