TPS650864: Settings program
Part Number: TPS650864
Other Parts Discussed in Thread: TPS650861
Hi support team,
Can the output voltage and other settings of the TPS650864 be changed programmatically?
If I want to change the settings, should I use the TPS650861?
Dice-K
  • Thank you for your inquiry. US and Europe TI offices are closed on April 18th. This thread has been assigned but you will receive a response early next week. Thank you for your patience!
    Katie
  • Hi Dice,
    Once the device is powered up, you can change the settings on TPS650864 via I2C, but remember it will go back to default values after a power cycle.
    This device has OTP, so you will have to use the user programmable version, TPS650861, to burn the desired settings.
    Sathish
