TPS65219: Settings program
Part Number: TPS65219
Hi support team,
Is the TPS6521905 the only TPS65219 series device that allows programming of output voltage settings, etc.?
Can settings be changed on devices other than the TPS6521905?
Is there a limit to the number of times it can be rewritten?
Dice-K
  • Thank you for your inquiry. US and Europe TI offices are closed on April 18th. This thread has been assigned but you will receive a response early next week. Thank you for your patience!
    Katie
  • Hi Dice,
    Thank you for reaching out on e2e.
    05 version of the device gives the full user programmability of the device, but since this device has EEPROM, any version the device can be programmed to the desired settings.
    There is a limit about 1000 times you can program the device.
    Sathish
