Hi Experts,
Customer is trying to make a BMS system using the BQ76905 chip and have following query:
We have autonomous control of the FETs working but when try to send a command to manually turn on/off a fet the device enters shutdown mode immediately, no delay.
For more context, we're using an STM32 as a host processor and powering out of the 3.3v REGOUT. We've set both the HOST_FETON/OFF bits, turned off the LFOWD bit to stop it from going into shutdown if there's an LFO fault. We've also set the STACK/CELL_SHUTDOWN voltages to 0 and the TEMP_SHUTDOWN to high.
Could it be an issue with me using manual and autonomous FETs at the same time? Any help would be appreciated.
Archie A.
