Other Parts Discussed in Thread: TPS22917,
Hi support team,
I have one question about the PPS3424A11C13ADRLR.
As attached, I have combined a push button controller (PPS3242A11C13ADRLR) and a load switch (TPS22917DBVR) to create a power switch peripheral circuit.
However, even when the button was pressed for the specified time, there was no continuity between VIN and VOUT of the TPS22917.
When I checked the output voltage of the RESET pin, it did not go high even when the button was pressed for the specified time, and only a pulse is output, as shown in the figure.
So could you please let me know why the RESET pin does not go high even when PB is pressed for the specified time, and how to solve this problem?
Dice-K
