The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
TPS6594-Q1: TPS6594-Q1
Part Number: TPS6594-Q1
Other Parts Discussed in Thread: DRA829
I have assembled PCBs with DRA829 processors with PMICs TPS65941213 and TPS65941111.
Most of the cards have worked, but, in a few cards, the buck outputs of PMIC was not seen
The register values of problematic PCB PMICs are captured and compared to the working PMIC register values (Refer sheet Initial of the enclosure)
The registers 5C and 5D of PMIC-A indicate over current interrupt at buck 1, 2, 3
So, the capacitors at the processor related to the Buck 1,2,3 outputs are removed while the capacitors at output section of the PMIC are retained
This step has lead to no change in the PCB (no output at buck 1, 2,3).
The register values read after removal of capacitors at the processor are listed in the same enclosure, in sheet named After Capacitor removal
Please suggest further course of action
Thank you
  • Part Number: TPS6594-Q1
    Thank you
    Register Comparison_R1.xls
  • Hi Kartheek,
    You mention enclosure and a sheet with some data, but I don't see an attachment. Can you try to attach the file? When posting, either drag and drop the file into the post body, or go to Insert > Image/video/file and Upload from that menu.
    Katie
  • Hello Katie,
    Thank you for the response
    The attachment is at the end of my message, after Thank you
    I am attaching the file again to this message
    0358.Register Comparison_R1.xls
