Other Parts Discussed in Thread: TPS65987
Hi AE,
The customer is currently using the TPS65987, but would like to understand the meaning and application of each register.
Could you help explain the function description and confirm whether this setting can be viewed using Ellisys?
Register
Option name
Function description
Ellisys log
1
Port Configuration(0x28)
Type-C Supported Options
2
Port Configuration(0x28) |
USB3.0/3.1 Rate
3
Port Control(0x29)
PD Mode
4
Port Control(0x29)
Process Swap To Sink
5
Port Control(0x29)
Initiate Swap To Sink
6
Port Control(0x29)
Process Swap To Source
7
Port Control(0x29)
Process Swap to UFP
8
Identity_Data_Object(0X47)
Product Type (UFP)
9
AlterXte Mode Adapter VDO
USB SS SigXling
10
VBUS Required
11
Vconn Required
12
Vconn Power
13
Display_Port_Capabilities(0x51)
DP Receptacle Indication
14
DFP_D / UFP_D Connected
15
Transmit_Sink_Cap(0X33)
Peak Current
16
Ask For Max
Autonegotiate Sink(0x37)
USB Communication Capable
Best Regards
