TPS2660: 402kOhm to RTN - is there flexibility
Part Number: TPS2660
Team,
I would like to understand the flexibility in selecting the 402kOhm resistance to RTN to select the Mode 'Current limit with latchoff'.
For the assembly of the PCB it would be much better to use a 442kOhm resistor as it is already used in the design. This would help to avoid needing another resistor reel in the assembly process.
What is the flexibility on the 402kOhm resistor that is mentioned in the datasheet? Is a 442kOhm resistor acceptable?
Thanks!
Frank
