TLV61046A: TPS61046
Part Number: TLV61046A
Dear sir I would like to use your TLV61046ADBVR in several projects all with 3.0 volt battery power supply, interesting for the presence of isolation mosfet and integrated diode.
Previously I used the TPS61041DBVR. I have already written to you to decrease the inrush current by adding diode and RC.
I use the step up to charge a 4400uF capacity to 16 volts. Everything works perfectly if it were not for the current which is 0.9 amp for 0.4 sec (as in data sheet !!) and which exceeds my availability given the use of small batteries. (NB I also added a supercap but this is not always possible). The previous TPS61041DBVR was limited to 250ma and was certainly better.
Do you have any proposals in this regard?
How can I decrease the switching current except by placing resistors in series? Is there any alternative component? Maybe equivalent pin to pin?
Thank you very much, best regards Gianni
