Dear Texas Instruments Support Team,
I am currently working on integrating the BQ27426 fuel gauge IC with an Arduino-based system. While communication with the device has been established, I am encountering difficulties in setting the battery Chemical ID.
Could you kindly provide any reference code or guidance on how to properly set the Chemical ID using an Arduino? Additionally, if a library or resource is available to retrieve all supported parameters from the BQ27426, it would be greatly appreciated.
Thank you for your support.
Nandish
