Part Number: TPS543C20A
Other Parts Discussed in Thread: TPS543B25, TPS543B22
Hello team,
I'm looking for the right device to meet the customer's requirements as below. Can you please recommend DCDC converter?
- Vin: 12V
- Vout: 0.85V
- Iout: 25A
- Fsw: 200kHz~300kHz
- PMbus or I2C is not needed, preferring pin strapping, easy to use
- External synchronization is necessary. Device should start with Fsw set by RT, after power-up FPGA, FPGA will provide external clock to the DCDC. It looks TPS543C20A does not support this use-case
Austin
