Hallo,
We are using UCC28065 to build 600W interleaved TM PFC.
But we are facing with a critical problem when we start debugging the circuit.
As you can see in the snapshot below, when we start debugging with 50W @380Vdc load, the driver pin GDA will output several pulses after a normal control pulse. And the inductor current seems to be relevant with these unexpected following pulses:
