What is the maximum inrush current capability of TPS1HB35
Please provide inrush current capability of TPS1HB35 for a 47uF capacitive load , wire length 1m .
The TPS1HB35 is not recommended for capacitive load charging. When the device hits current limit it will disable the switch immediately.
Devices for capacitive charging applications it is recommended to use the TPS1HA08 or the TPS1HC08 as they clamp the current when limiting happens rather than immediately shutting off the switch.
BR,
Alan
