Other Parts Discussed in Thread: TPS28225, UCC27425
Can you please suggest if you have a Complementary MOSFET (n & p channel enhancement) Gate Driver IC that can:
(a) Accept a single ended input as shown
(b) Switch ON one of the two MOSFETs when Input signal is positive ("A" in pic above)
(c) Switch ON the other MOSFET when Input signal is negative ("C" in pic above)
(d) Switch both MOSFETs OFF when input signal is zero/ground ("B" in pic above)
Kind Regards,
~Sujith
