Other Parts Discussed in Thread: BQ25505, BQ25750
Can BQ25505 and BQ25750 support nickel-metal hydride batteries (NiMH)? If not, what problems will occur when used with NiMH batteries? For BQ25172 used with NiMH, is it better to have a higher or lower input voltage? This voltage will affect the design of my solar panel. I want to know whether 4 series or 2 parallel and 2 series of batteries have higher efficiency. Also, can different charging efficiency curves be provided (the specification sheet does not have data under various different test conditions)?
