Part Number: TPS709
Hi Team,
Can you suggest a alternative of TPS709A33DBVR that output disable when EN floating
Part Number: TPS709
Hi Team,
Hi Kailun,
Can a pulldown resistance of approximately 100kΩ be added externally? This would ensure the TPS709A would remain disabled unless actively pulled high.
Alex Davis
Hi Alex,
This is applied in pack, the power consumption 100kohm brings is unacceptable for customer.
Hi Kailun,
It does not appear that any of our LDOs with a similar quiescent current, supply range, and output current have an enable pin with this behavior. An external logic gate or resistor pulldown may be able to achieve this behavior, but will depend on the customer's other requirements.
Alex Davis
