Hello -
Our customer is requesting information regarding the gold plating nominal & max thickness for our TPSM82903SISR.
Can you please advise?
Thank you,
Andrew
Hello -
Thank you,
Andrew
Hi Andrew,
You can find this useful: (+) [FAQ] What is the thickness of Gold (Au), Palladium (Pd), or Nickel (Ni) for TI's NiPdAu lead finish? - Logic forum - Logic - TI E2E support forums
As for NiAu: You can refer this whitepaper. It mentions "For a PCB using a Ni/Au surface finish, the gold thickness should be less than 0.5 µm to avoid a reduction in thermal fatigue performance"
Gautam
