Hi Team,
My customer is asking for assistance to confirm when some pins of the TPS3824-33DBVR reset IC are not used.
Specifically, we need to ensure that the unused pins do not cause any malfunction.
In the following circuit, there is no requirement for the WDI and RST (RESET) pins.
We will design theWDI pin with a 1K ohm resistor to ground, and leave the RST pin floating to ensure the IC operates in its optimal state.
Can you confirm that there is no issues with this configuration?
Thanks!
BR,
Alfred
