Hi Team,
Could you please provide the minimum input-to-output voltage ratio (Duty cycle) required for proper regulation in the TPS56637?
We are designing a regulator with the following specifications:
- Input Voltage (Vin): 6V to 14.5V
- Output Voltage (Vout): 5V
- Output Current: 2.5A
However, the simulation tool indicates that this configuration does not meet the minimum off-time requirement. Could you help clarify this?
